How to replace Aerial base mount.
Hi, I need to replace my aerial base mount on my 65 plate Berlingo. Could anyone help by telling me how to do it please or if there is a video out there in how to do it? Thank you
Pop out the light fitting inside the van in the centre to your upper left assuming you are in the drivers seat - this if i remember is also where your microphone is.
Behind that is is the nut - i'm going to say 22mm but its been a couple of years since i replaced mine. Dont try with an adjustable spanner, there isnt the room. You will also have a fair bit of foam in there for sound proof.
Undo that then depending if you have sat nav or not there will be 2 connections, one for FM one for DAB, one is grey, the other is orange. Bit fiddly to pop apart but thats just the clips. You will have three cables if you have satnav.
The new base will almost certainly have 3 cables as standard as this was the upgrade and they all have GPS built in as standard.
Reconnect and lock it all back down and do it all in reverse.
The plastic cowling is only clipped in, so some gentle work with a flat bladed screw driver will pop it out.
(11-11-2019, 09:52 AM)Tree Wrote:  Pop out the light fitting inside the van in the centre to your upper left assuming you are in the drivers seat - this if i remember is also where your microphone is.
Thanks for your help. Do you have any information on buying the aerial base? I’ve contacted Citroen to find out what one I’d need and where to get one but haven’t heard anything back. Thank you
just bought mine from the local dealership - i think i went in and ordered one, about £28 if i recall
Re: "Pop out the light fitting inside the van in the centre to your upper left assuming you are in the drivers seat - this if i remember is also where your microphone is."
How do you pop out the light fitting?  Is it just the light lense or the whole surrounding housing?
Have been googling for hours and and am coming up short :-(
Attached Files Thumbnail(s)
It’s the whole surround. You’ll need to disconnect your light so it’s not hanging in the way. If I recall there are four tabs holding it in place.
[-] The following 1 user says Thank You to Tree for this post:
  • flatbob
(11-01-2020, 04:44 PM)Tree Wrote:  It’s the whole surround. You’ll need to disconnect your light so it’s not hanging in the way. If I recall there are four tabs holding it in place.
That's the ticket - photos attached for anyone to see - thank you.  Just prise carefully around the edge of the housing with a thin small screwdriver or somesuch.
Bumper with led
Last Post: Lingo09
Yesterday 05:54 PM
Amdro boot jump for sale
Last Post: Jaybee
Yesterday 04:41 PM
Paint advice
Last Post: Andhall
Yesterday 02:35 PM
Should I buy this van?
Last Post: Duggie12
25-03-2025 09:27 PM
sliding door panel removal
Last Post: mojito
25-03-2025 07:13 PM
Twin Cam Chain Snapped need some Parts Advice
Last Post: kingy1912
25-03-2025 01:10 PM
Rumbling Noise 55-65mph
25-03-2025 01:06 PM
XL tyres
25-03-2025 01:03 PM
Last Post: deejay_xb
23-03-2025 10:06 AM
» Replies: 32
Unusual Braking Problem
23-03-2025 07:57 AM
