High crankcase pressure
Hi, my 2012 berlingo seems to have high crankcase pressure. Blowing spots of oil out of the dipstick and blowing the oil filler cap around/upside down when unscrewed.
I'm thinking possibly head gasket?
https://youtu.be/NkzCGHPvMu8
(22-11-2019, 02:36 PM)Johnb799 Wrote:  Hi, my 2012 berlingo seems to have high crankcase pressure. Blowing spots of oil out of the dipstick and blowing the oil filler cap around/upside down when unscrewed.
High crankcase pressure is a sign of piston blow by 0r a blocked breathing system.
A blown head gasket would pressurise the cooling system but not  the crankcase.
I would try the breathing as is more likely & easier to check.
As Ron says ^^^^
Hi, thanks for the reply. I've checked the breather, made sure pipes were clear, it'll blow up a balloon on the end of the pcv hose, is there more than one?
Just a thought, are the injectors all tight?
1.6hdi starting problem
Yesterday 01:38 PM
12-10-2026 02:50 PM
12-10-2026 02:31 PM
12-10-2026 11:22 AM
» Replies: 76
06-10-2026 12:46 PM
06-10-2026 10:00 AM
