Threads: 2
Thanks Given: 2
Over the last month or so the mpg seems to have dropped off, normally get around 600 miles to a tank however i drive it i'm now getting less than 500
Done the obvious forced regen but its made no difference , could it be something else ?
63 XTR 1.6 HDR 115 64000m
Threads: 29
Thanks Received: 14 in 13 posts
Thanks Given: 4
Maybe its just the winter diesel they use this time of year, I get about 4mpg less as soon as it starts getting colder. Dark and rainy nights = headlights and wipers on more, longer to warm up so less efficient. It all adds up.
Threads: 2
Thanks Given: 2
(24-11-2019, 05:04 PM)Peter Palmer Wrote: Maybe its just the winter diesel they use this time of year, I get about 4mpg less as soon as it starts getting colder. Dark and rainy nights = headlights and wipers on more, longer to warm up so less efficient. It all adds up.
It didn't do it last year ?
Threads: 12
Thanks Received: 386 in 274 posts
Thanks Given: 16
37
When you say you did a forced regen, what do you mean, do you have diagbox ?
Threads: 2
Thanks Given: 2
(24-11-2019, 10:35 PM)Lighty Wrote: When you say you did a forced regen, what do you mean, do you have diagbox ?
What i really meant was i did 30 miles in 4th gear doing 70mph
Threads: 20
Thanks Given: 2,126
18
I thought it would regen on a decent run irrespective of gear selection?I would love comments on this.
Strawberry flavoured windows
Threads: 2
Thanks Given: 2
(25-11-2019, 10:21 PM)ron Wrote: I thought it would regen on a decent run irrespective of gear selection?I would love comments on this.
I was recommended to do this ?
Besides fuel usage is less than 500 has been 600+ for the last 2 years.
Have had no warning lights or anything abnormal happening ?
Threads: 12
Thanks Given: 16
37
26-11-2019, 08:48 PM
(This post was last modified: 26-11-2019, 08:49 PM by Lighty.)
Ok, so driving in 4th at 75 does not = A forced regen.
I have to be honest and admit I do not know the exact criteria, but it is way more likely to be driving in 4th or 5th gear at 40 or 50 mph, at least 1/4 rank of fuel & engine temp at normal, all windows shut.
Once the car detects these criteria , it will alter the fuelling & ignition timing, which will increase the dpf temp high enough for a regen.
Driving it like you have done, will not work Iam afraid , dpf temp nay get to 150/180 degrees, where as on a regen it will exceed 350 degrees.
A workshop can initiate a “forced regen “ on a laptop, by strictly following very specific instructions, if all criteria is met , then a regen will occur.
Threads: 8
Thanks Received: 504 in 452 posts
Thanks Given: 305
35
You can put your hat on upside down and drive it anyway you want, but it won't do a regen unless the soot content is over a set level.
