28-11-2019, 03:09 PM
Hi
Owner of a 2009 Berlingo First 1.6Hdi. First time posting.
Car won't start, turn ignition key and lights on dashboard come on, turning key fully to start engine does nothing, no sound coming from engine bay, as though no power getting through to starter motor. I checked all fuses in the engine bay hoping to find a blown fuse but did not. Central locking works ok so I'm sure battery is fine (only replaced last year).
2 events happened recently which I think are related as follows
1. Whilst driving the car, warning beeping started and the red S T O P on the dashboard was flashing, I slowed the car down to an idle and waited with the engine idling then the beeping stopped and the red flashing STOP went away. I was then able to continue driving without any problem evident.
2. On another day, the same problem described in the first paragraph above happened, a neighbour who is a mechanic took a look at it, took off the positive terminal from the battery and touched the engine block with the positive terminal then put the terminal back on the battery and then the car started fine. I was then able to drive the car for a few days.
My mechanic friend is not about just now for me to get advice, I tried his fix as described in 2 above but the car won't start.
Any thoughts on this will be appreciated.
Michael
Michael
