Threads: 46
Thanks Received: 160 in 129 posts
Thanks Given: 34
23
Got in the Berlingo today [Multispace B9 1.6HDi 2008] and the blower doesn't appear to be working on any setting. Haven't had a chance to investigate yet but what is the likely cause if not working on any setting. Is it likely to be the resistor pack if all the settings have failed? [They were all working previously]
Thanks for any pointers into the correct direction.
Threads: 19
Thanks Received: 4 in 4 posts
Thanks Given: 2
I'm also having problems with my heater although mine seem to blow air on all settings except my feed get frost bitten because there seems to be very little air going to the floor.
Has anyone had this problem?.
It's also made worse by cold air coming in under the drivers side dash somewhere
Sent from my SM-G920F using Tapatalk
2012 (62) B9 Berlingo 1.6 Hdi (75hp)
Threads: 20
Thanks Received: 7 in 7 posts
(12-12-2019, 12:15 PM)webcrafty Wrote: I'm also having problems with my heater although mine seem to blow air on all settings except my feed get frost bitten because there seems to be very little air going to the floor.
Got the same problem as many many others do, I've stuffed a big piece of dense foam in there.
Still cold feet, full blast helps a bit.
I did start a thread on it
Multispace B9 2009 1.6HDi
Threads: 20
