Replacing injector
Hello there I have had a leaking injector and have got it out and cleaned it up and the seat does anyone know how to get plastic spacer out or hole or can I reuse old one?it is 1 bolt type or injector, also when I test fit injector back in its hole it doesn’t seem very snug is that normal!! Many thanks happy new year!
G'day - plastic spacer bit I've usually left in but replaced the big rubber grommet and the copper washer down the bottom of the injector 'pit'.
It should be tight in there once you have all the bits tightened up - is the copper washer back in there OK?
Thanks I hadn’t realised that the old injector seal had melted onto the injector that’s why I couldn’t find it, bolted it back up now just gotta fit new leak off pipe due to me snapping off green clips ,does anyone know a easy way to remove the leak off pipe?
Emissions fault.
11-05-2025 06:29 AM
10-05-2025 05:31 PM
Winter Tyres
10-05-2025 02:42 PM
Start stop on van
Last Post: Rhino2k
09-05-2025 10:28 PM
09-05-2025 09:34 PM
Insurance Shocker !!!
Last Post: Keefus.
09-05-2025 01:45 PM
Part of Dipstick Stuck
Last Post: Nice4dad
09-05-2025 01:25 PM
BSI central locking again
Last Post: stuffe
09-05-2025 09:24 AM
» Replies: 23
steering column bearings
07-05-2025 07:53 PM
Gen 1 cream interior cleaning
07-05-2025 06:28 AM
