Misfire 1.4i berlingo van
Hey guys,
So I got a 1.4i 2006 berlingo van bi fuel.
It's got an intermittent misfire.
It had the EML on when i brought the van with code p0420 but with no driving problems at all. Deleted code and all was fine for months and quite alot of miles
Then the day before the mot it starts misfiring, uphills mostly and a lumpy idle from cold with no EML. Passed emissions test at mot.
Took spark plugs out and they don't look very old tested continuity ect cleaned them up and stuck them back in.
Changed the coil pack for a brand new one but problem still remains still with no codes.
So I tried running it of LPG to see if I still had the fault and it still has the same fault.
Then driving at 60mph it misfired EML came on and went into limp mode got it home and read the codes they are as follows
trouble codes
p1157 as far as i can tell its a lean code
p0122 TPS circuit a low imput
P0351 Ignition Coil A Primary/Secondary Circuit Malfunction
po352 Ignition Coil B Primary/Secondary Circuit Malfunction
pending code
p0135 02 censor heater circuit
In summary
spark plug seem fine, its had a brand new coil pack, fuel trims are in parameter, can't be fuel pump, pump relay, filter or injectors as it still misfires on LPG. Compression test showed cylinder 1 and 4 are 150psi and cyliders 2 and 3 are 125psi seems to be good compression.
Anyone have any ideas on this been told by a mechanic it could be the 02 censor but they have not had a look at the van.
Thanks in advance.
I would start by putting new plugs in so you know they are good, seems strange happens uphill has the fuel filter ever been changed it could be causing issues. Is the wiring to the coil pack and connectors all good. Did you buy a decent make coil pack as there are some real crap out there and a decent brand costs money. Sorry cant be more specific.
(03-01-2020, 07:56 PM)Tomcat3 Wrote:  I would start by putting new plugs in so you know they are good, seems strange happens uphill has the fuel filter ever been changed it could be causing issues. Is the wiring to the coil pack and connectors all good. Did you buy a decent make coil pack as there are some real crap out there and a decent brand costs money. Sorry cant be more specific.
Hi thanks for your reply new plugs are on the list next just trying to justify spending £12.99 per plug as its LPG. If you know of cheaper ones that would be great.
I haven't changed the fuel filter but it can't be petrol related as it happens on LPG.
The ignition coil is bougicord not sure how good they are but its the only one I could get at the time and was the more expensive one any way. I suppose going to the dealership would have been better but had no time.
Wiring all seems ok but I don't have any wiring diagrams to test them.
Disconnect o2 sensor. Just unplug connector.
Take it for spin on petrol and on LPG.
Report back...
Disconnect o2 and engine will be running rich.
Just to rule out lean condition...
Do you have lexia ?
If yes then post pic of additional info from above error codes.
That would help in diagnose.
Best regards,
brajomobil
(07-01-2020, 07:40 AM)brajomobil Wrote:  Disconnect o2 sensor. Just unplug connector.
Report back...
Do you have lexia ?
Best regards,
brajomobil
Hi Brajomobil thanks for your reply.
No lexia unfortunately
I have already disconnected the o2 took it for a drive and it ran with no problems.
Then it seems that lean condition is causing your misfire.
Probably your O2 sensor is bad.
If you want to be 100% sure before you replace 02 sensor
then I need voltage plot over time from your OBD diagnostic program.
This is just for reference: https://mechanics.stackexchange.com/ques...-and-p0420
Best regards,
brajomobil
Yeah, the O2 sensor is the likely culprit.
If it suddenly studders during uphills, it means it's running too lean, and the additional stress is enough to overload the engine.
I bet that if you quickly step on the clutch or take it into neutral the engine will return to running 'normal' again.
Source; have a slightly older 1.4i that doesn't always behave as it should...
These engines are very good as long as you take care of them. But ignore tham and they will sulk, whine and finally make your day a complete misery.
I have the same issues but i think I have 2 problems.
1 being injectors not firing right (obviously not applicable to you)
2 being the intake air temp sensor. I'm not sure if that's lingo for an o2 sensor but it's chucking the code at me so I'd take a punt for 20 odd quid or whatever it is. It tells the engine what ratios are needed so it plays a fairly bit role in smooth runnings.
I cleaned mine down with some spray as mine is build in with the MAS and it seems better(ish) but I need to sort the injectors to know for sure.
Good luck!
If it is throwing up code P 0135 oxygen sensor bank one it means the oxygen sensor or lambda sensor that is mounted in the exhaust manifold right in front of you. The lower one is bank two after the cat. They can be a right sod to remove if its been in for years. I built a pool out of mastic around the sensor and left it for 5 days and it nearly didn't give up. I tried every tool and socket going in the end a 22mm crow foot socket fitted tight and on a breaker bar moved it in the end.
I've got a misfire on my 2001 Berlingo 1.4i petrol, with, I think, an after market LPG conversion. I replaced the MAP sensor which improved it, so I figured I'd try replacing the air intake temperature sensor. I am presuming that this is something to do with the air flow into the inlet manifold. The part looks like the attached image. The problem is, I can't see where it goes. I can't see a part like this near the inlet manifold. Can anyone help, and tell me where it's supposed to go?
Attached Files Thumbnail(s)
Today 12:02 PM
Berlingo 2026
Today 03:17 AM
Yesterday 02:32 PM
09-07-2026 12:15 AM
09-07-2026 12:12 AM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
Next gen Berlingo coming 2030
08-07-2026 04:23 PM
New belingo
Last Post: John doe
01-07-2026 02:14 PM
P1A9C
29-06-2026 06:05 PM
28-06-2026 03:35 AM
