[Engine] STARTING PROBLEM
Hi Guys, been a long time since posting on here due to the on-going reliability of my Berlingo 2.0 ltr Hdi but now I have an annoying problem. On cold start up the engine turns over quite slowly until after only a couple of seconds it virtually dies giving you the impression that the battery is dead, then after turning off the ignition and trying again it starts straight away. For the rest of the day start up is normal with perfect performance,no overheating etc. This has been like this for about 6 weeks but just recently its been gatting worse resulting in today being unable to start until turning on and off 5 times before it would turn quick enough to fire. As before,once fired up performance was normal with no overheating,no water loss etc. I,m now concerned that sooner or later it wont start at all so any advice would be most welcome.
There are quite a few posts on the forum about the M59 2.0 hdi engine and its starter motor. They all point to a tired starter motor and some rebuild it but others go for a replacement and there is an uprated starter that others have fitted with good results. Have a search on the forum.
Thanks Tomcat3 for your reply and as a result of spending an hour or so searching through the relative posts re poor starting I have put the car in for a new starter motor on thursday. Lets hope this solves the problem and I can return to reliable motoring once again !
ive had a 04 berlingo 2.0hdi and now own a 05 berlingo 2.0hdi and on both cars i fitted a heavy duty starter from ebay. and recon its the best thing ive done to them instant starting .and if i buy another one it will be the first thing i would do to it.the spin over is so much faster. the starter is biger and have more teeth .i cant recommed this upgrade enoth...
£73.95 each
(07-01-2020, 05:41 PM)auspom48 Wrote:  Thanks Tomcat3 for your reply and as a result of spending an hour or so searching through the relative posts re poor starting I have put the car in for a new starter motor on thursday. Lets hope this solves the problem and I can return to reliable motoring once again !
Had same issue. Serviced the starter, solved.
Thanks for the confidence booster! it goes in tomorrow and then hopefully the problem will be solved. Will be reporting back later!
[-] The following 1 user says Thank You to auspom48 for this post:
  • Civvic
UPDATE !!  New starter motor has fixed the problem and I now have a working horn which has been U/S for 3 months. probably the disturbance of relative cabling has re-earthed the horn back into life, gotta be better than removal of the front bumper !!Thanks again guys.
  • GraemeT
Yet another ABS fault
Today 10:56 AM
Mileage
Last Post: Taffy747
11-05-2026 11:51 AM
11-05-2026 09:17 AM
03-05-2026 01:27 PM
Head unit quad lock
03-05-2026 11:17 AM
Spare Key Fob?
29-04-2026 08:05 PM
29-04-2026 06:27 PM
Eolys problem
24-04-2026 07:07 PM
Last Post: oldbury863
24-04-2026 12:42 PM
Last Post: LucyLeBingo
20-04-2026 02:42 PM
