Ply lining on the roof
Hi all, am currently converting my Berlingo van to be used as MTB transport with the occasional night sleeping in it. I have ply lined, insulated and carpeted the floor and sides, but was wondering if anyone has managed to line the roof? Most photos and ply kits i have seen on google don't have a roof sheet. Is there a reason for this? I want to insulate the roof and add some string lighting so need to put some ply over the top. I think it should be possible, but just the lack of availability and examples of people doing it has made me wonder if it can't be done for some reason?
Nobody does kits for the roof because it doesn't often get bumped from the inside. Carpet stuck on with spray adhesive is the usual roof lining material.
Ahh right, I guess I will be a pioneer then! I need to put wool insulation and some string lighting up, so need to install a ply panel over the top of it.
11-07-2026 12:02 PM
Berlingo 2026
11-07-2026 03:17 AM
10-07-2026 02:32 PM
09-07-2026 12:15 AM
09-07-2026 12:12 AM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
Next gen Berlingo coming 2030
08-07-2026 04:23 PM
New belingo
Last Post: John doe
01-07-2026 02:14 PM
P1A9C
29-06-2026 06:05 PM
28-06-2026 03:35 AM
