[Engine] ECU harness multiplug breakout box? 2.0HDI 2004
Hi
I have an intermittent starting problem and I think it is either the the fuel pressure sensor or  the pressure regulator control solenoid (or the wires that connect these)   I want to be able to check it at the ECU multiplug to isolate the problem.
-  the information I have says I need a breakout box  (see pic below-  note 8)-   is it possible to get such a thing?
-  Ive had a look on ebay and not been able to find
many thanks
jim
Welcome to the forum.
Your picture didn't make it on the post.
I think that a multimeter will do what you need to test the wiring continuity. I'm not sure that a breakout box would be any better, even if you can find one.
Rear door filling with water
Yesterday 06:56 PM
MOT Emissions repeated fail
Yesterday 06:53 PM
Last Post: rom4ik
20-01-2026 04:11 PM
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
