Strange radio installation problem
I have a 2009 Multispace diesel 1.6.  The original radio was replaced some years ago with a Sony Stereo which suddenly stopped working.  I used a multimeter to confirm that 12.5 volts was being delivered to the final connector and checked the fuse in the radio was ok.  No life at all so I bought a low cost Bosskzi radio.  This does'nt powere up either so I am guessing the radios are ok and I am missing something in the vehicle.  I attached my multimeter to the yellow and black wire terminals and get 12.5 v so I assume that earthing is taking place via the black wire.   I also have the aerial plugged in.
I am hoping someone can suggest an aspect I have overlooked.
Are you getting +ve volts at the red wire?
Red is ignition switched live & Yellow is perm memory live
Citroen C8 - Picasso - Toyota Yaris - Honda Nighthawk - Super Blackbird - Grom
(12-01-2020, 02:21 PM)Ultrawomble Wrote:  Are you getting +ve volts at the red wire?
Thanks for the help - no power at the red wire so I hope that its just a fuse replacement.  Unfortunately the fuse box in the glove compartment hides the fuses behind several wire bundles and I am very wary of pulling them about to reach the fuse!
(12-01-2020, 06:34 PM)ronhud Wrote:  Thanks for the help - no power at the red wire so I hope that its just a fuse replacement.
I think it's F4 bottom left hand side of the box as you look at it.
Sent from my BND-L21 using Tapatalk
I tried to check the F4 fuse but even after removing the glove box I could not get at the bottom left hand side fuses. It is really unbelievable that Citroen could feel happy with such a bad design. Even pushing the various wire looms aside there are fuses that are unreachable. I checked all the fuses I could reach and they were ok so I have arranged to have an auto electrician look at it.
Yesterday 10:10 PM
» Replies: 21
Berlingo undertray
Yesterday 09:59 PM
» Replies: 19
Air filter box removal
Yesterday 06:18 PM
Yesterday 04:25 PM
Yesterday 07:07 AM
05-03-2026 08:16 AM
03-03-2026 06:17 PM
03-03-2026 07:57 AM
02-03-2026 02:51 PM
02-03-2026 02:14 PM
