Berlingo not starting
Hello everyone. I have a 2008 berlingo 1.6hdi van which died on my gf yesterday going to work. Been running fine up u till then. She said the fuel light came on when she was driving home for lunch then when she went back to work it died on her at a junction so she free wheeled across the road and parked it up. She tried to start it and it turned over but wouldn’t start. So I went down to the van later on that day and turned it over and it started with me for about 5 seconds and stopped again. I tried again but no joy so had it towed home. I tried adding more fuel I cause it was just to low and checked the flow diesel line and fuel comes out of this when I turn it over so wondering if its got a airlock possibly? I did put new injector seal in it about 2 months ago and has been run every day since with no problems so slightly confused as to why it’s died. Anyone have any ideas?
You need to get rid of air in fuel lines.
Best regards,
brajomobil
My 03 Berlingo used to splutter and die when i got it first so changed fuel filter and full service...it was still doing the same afterwards but was worse when tank was low..eventually i droped the diesel tank and the screen which was part of the gauge was completely gunked up...cleaned it out and she ran sweet for the 11 years i had it..
first thing id do is change your fuel filter though and prime the life out of it...
My Vehicles: 2015 Berlingo Enterprise Van 75 1.6Hdi
                   2021 Nissan Qashqui 1.5DCi
^^^^ Yes use the manual primer ( bulb or plunger type ) and squeeze / push until firm - turning the engine doesn't prime the system or get rid of the air.
Today 01:49 PM
Yesterday 10:07 PM
11-07-2026 12:02 PM
Berlingo 2026
11-07-2026 03:17 AM
10-07-2026 02:32 PM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
Next gen Berlingo coming 2030
08-07-2026 04:23 PM
New belingo
Last Post: John doe
01-07-2026 02:14 PM
P1A9C
29-06-2026 06:05 PM
28-06-2026 03:35 AM
