Hi all. I have just bought a 2006 Peugeot Partner 1.9 to replace my 2005 Berlingo (also a 1.9) which sadly met its end when it was written off last month.
I have a couple of issues with the electrics on the Peugeot. The rear foglights are not working, neither is the fog lamp warning indicator on the dashboard. I checked one of the rear bulbs and it worked when I swapped it over with the brake light bulb.Furthermore, with the engine running and the driver's door open, the glow plug warning light and the low fuel warning light come on, but go off again when I close the door.
I have tried resetting the BSI a few times, but there is no difference to any of the above. Would anyone be able to help point me in the direction of a solution please? I should add that there is a towbar fitted, if that makes any difference.
Thanks in advance,
John
Thanks in advance,
John
