NO HORN !!
Hello again, having successfully solved the poor starting problem by changing to a new starter motor I have since gained a non-working horn! This is a recurring problem first solved when the mechanic had to move certain cables to replace the starter motor thus disturbing the earth lead presumably. I have now followed the advice of several posters and performed the trick of re-earthing from the base of the steering column to the bulkhead with success. I have tested for possible fault codes coming on and so far all is good. Fingers crossed that this is a pemanent fix! Thanks go to all who suggested this simple fix previously.[Image: smile.png]
yup the earth can be a problem..
with mine a BSI reset fixed it
called Brian... Smile
I'm having same thing with the horn but my main dealer hasn't fixed it ?? that and all the other things wrong or not working makes for a sad customer ?
[-] The following 1 user says Thank You to Disheartened for this post:
  • Art b
(18-01-2020, 06:24 AM)Disheartened Wrote:  I'm having same thing with the horn but my main dealer hasn't fixed it ?? that and all the other things wrong or not working makes for a sad customer ?
The horn seems to be a real issue on berlingos. I've had 2 go and the only way I could get around it was either Re earthing it like the person above did and on the other I put in a separate horn.
I think the problem is under the air bag in the wheel but I'm not into removing air bags so I just earth it for the Mot which just about gets it through. Then I rip it all back out because there's no decent way I can find to do a permanent earthing.
same problem....can some one put up pics of the earth off steering column plz
[-] The following 1 user says Thank You to Wellmound for this post:
  • Art b
(13-02-2020, 01:00 PM)Wellmound Wrote:  same problem....can some one put up pics of the earth off steering column plz
you can put an earth clamp,
 on the base of the column,earthed to the body ..
Hi guy untill today i couldnt get the horn...i took airbag off tested everythin it all worked fine...even live from the wheel to airbag...so i tweeked the little tangs on the air bag...now i have good horn...gope this helps as iv not see anyone suggest tweeking the connector tangs......
(22-02-2020, 02:09 PM)Wellmound Wrote:  Hi guy untill today i couldnt get the horn...i took airbag off tested everythin it all worked fine...even live from the wheel to airbag...so i tweeked the little tangs on the air bag...now i have good horn...gope this helps as iv not see anyone suggest tweeking the connector tangs......
Can't beat a good horn...!
Nb
(Smilies don't work)
Great idea! My lash-up has failed a number of times. Not sure of the best cable - braided I guess.
Any 1.5 mm cable will do, bigger if you must / only have bigger.
Braided, why ???
You'll be wanting armoured cable next lol
Mirror cap replacement
Last Post: Pedronicus
Yesterday 09:26 PM
New member in Scotland
Last Post: Stretch
Yesterday 08:51 PM
Last Post: Grizz
Yesterday 08:17 PM
» Replies: 1041
Clicking from fuel pump area
Last Post: Stretch
Yesterday 08:04 PM
Sliding door handle
Last Post: kaney
Yesterday 07:14 PM
Hola a todos!
Last Post: Mike
Yesterday 05:47 PM
Radiator fan cycling on / off every few seconds ...
Last Post: Berlingboy
Yesterday 01:53 PM
Wiring trailer lights without factory trailer pr...
Yesterday 01:35 PM
da.Nm vs. m.daN torque settings
Last Post: saskak
Yesterday 12:26 PM
Citroen-Shop.eu
Yesterday 11:48 AM
