Front clunking
Hello when the weather gets to 3 degrees and cold I get a clonk coming from right front wheel I have checked spring, no obvious play in ball joints lower arm etc I seem to remember a post about the internals of the front shock can make a noise but only apparent after it’s on the bench any help would be appreciated cheers zcarz
Have you checked the top mounts?
I had an intermittent knocking in the front left, rest of the suspension components appeared to be ok when tested so replaced both sides.
Matt
Droplink maybe? Easy enough to change those before biting the top mount bullet. (Having said that all our Pugs & Berlingo needed new top mounts at around 110,000 miles)
Take the drop links off and drive the car round the block, if the clonk has gone you've probably found the problem.... I say probably because with the drop links removed the anti roll bar mounts won't be being stressed and it's possible for them to give a clonk noise if worn.
  • tomhick024
Assuming that you can’t see anything, then it’s most likely the top mount or damper.
The strut will need to be removed & the spring stripped off.
Once you have the strut on its own, check for “rock “ in the piston.
Any movement will need a new damper.
The top mount has a steel bush bonded into the rubber, these split away from the bonding & get noisy.
  • tomhick024
Berlingo undertray
Today 06:24 PM
» Replies: 15
Today 08:32 AM
Today 08:16 AM
03-03-2026 06:17 PM
03-03-2026 05:08 PM
03-03-2026 07:57 AM
02-03-2026 02:51 PM
02-03-2026 02:14 PM
Amdro boot jump for sale
Last Post: YTC1
28-02-2026 09:48 PM
Last Post: Muppets on Mars
27-02-2026 01:57 PM
