[Engine] Emissions
Hi, I have a 2012 Berlingo 1.6HDi, I am having a problem with the emissions, when booted it puts out black smoke, there has been no fault codes and running absolutely perfect, over the last few days when idling it has been running uneven and stalling unless there was revs on the engine, but perfect with revs on, now it has put up code P2175.
Any clues of what I can do to sort it?
Thanks in advance
Welcome to the forum.
That code seems to relate to the throttle body / dosuer which is on the left / front connected to the left of the 2 large rubber hoses that go to/from the intercoler.
It could be related to the air mass sensor which measures the air coming into the engine. It sits in the air intake pipe.
Try unplugging it and see what happens. They go duff now and again.
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
(29-01-2020, 10:38 AM)cancunia Wrote:  Welcome to the forum.
Hi, thank you for the welcome, I will try a replacement throttle body, I have replaced the Air flow sensor, no joy, I will let you know the outcome
(29-01-2020, 10:39 AM)brodfather11 Wrote:  It could be related to the air mass sensor which measures the air coming into the engine. It sits in the air intake pipe.
Hi, thank you for the reply, I have already replaced the air mass sensor, unfortunately no joy there, I am going to try the throttle body next as per another reply, any advice much appreciated
(29-01-2020, 10:52 PM)Tangled Wrote:  Hi, thank you for the reply, I have already replaced the air mass sensor, unfortunately no joy there, I am going to try the throttle body next as per another reply, any advice much appreciated
The throttle body has 2 or 3 sensors inside, it may be one of them that's faulty.
11-07-2026 12:02 PM
Berlingo 2026
11-07-2026 03:17 AM
10-07-2026 02:32 PM
09-07-2026 12:15 AM
09-07-2026 12:12 AM
1.6hdi Euro 4 Swirl flaps
08-07-2026 11:51 PM
Next gen Berlingo coming 2030
08-07-2026 04:23 PM
New belingo
Last Post: John doe
01-07-2026 02:14 PM
P1A9C
29-06-2026 06:05 PM
28-06-2026 03:35 AM
