Thanks Given: 1
Hi, could anyone let me know where the heater blower resistor is located on a right hand drive 2004 Berlingo, is it on the passenger side behind the glove box, or is it on the drivers side near the steering column, any pics anyone has would most welcome, with kind regards Kelvin
Thanks Given: 188
23
On mine with air con you take the fabric trim down below the glovebox then look up toward the centre back of the dash. I think its held in by one or possibly two screws. It has a big connector block and heavy wires going to it this just unclicks and comes off. Don't go guessing which resistor pack you have there are a few different versions so remove yours first and then compare on websites. If its the original one it will have a part number on it. If you aint got air con it is far less crowded around it.
Are we there yet?????
• Kelvint
