Non starting 2.0HDI 2004
Hi
HELP PLEASE Car wouldnt start this morning.
Always been a bit weird on starting TBH
Turn the key first time and it sounds like the battery is low,doesnt fire up
Try it again and the starter runs and the car starts normally.
This morning same first attempt slow starter, doesnt fire
Go to start again and nothing !  All lights on but starter not engaging, try spare key etc nothing !
Put a boost pack on the battery (But all lights and wipers working fine) still nothing
The ignition does feel a bit 'muddy' is the best I can describe it but always been like this (Key doesnt turn too freely)
Not sure what to check first ?
Starter Motor ? or Ignition barrel /contacts ?
Thanks in advance
Phil
Starter motors on the 2.0 hdi are a know weak spot and the cause of many starting problems, ive changed loads of them - make sure you get a good quality one as the cheap ones are rubbish.
  • boltonboy
Thank you, I thought it must be as it was so random, slow start, then fast start
Appreciate the quick reply
hi if your buying a new starter ,buy a heavy duty one from ebay ive fitted 2 of these on my berlingos .the second ones starter was sill working ok but they make such a differance i had to fit one .there slighty bigger with a differant number of teeth.
[-] The following 1 user says Thank You to landcrab for this post:
  • boltonboy
Ok that makes sense
Emissions fault.
11-05-2025 06:29 AM
10-05-2025 05:31 PM
Winter Tyres
10-05-2025 02:42 PM
Start stop on van
Last Post: Rhino2k
09-05-2025 10:28 PM
09-05-2025 09:34 PM
Insurance Shocker !!!
Last Post: Keefus.
09-05-2025 01:45 PM
Part of Dipstick Stuck
Last Post: Nice4dad
09-05-2025 01:25 PM
BSI central locking again
Last Post: stuffe
09-05-2025 09:24 AM
» Replies: 23
steering column bearings
07-05-2025 07:53 PM
Gen 1 cream interior cleaning
07-05-2025 06:28 AM
