03-03-2020, 09:55 AM
For my MOT, I had an advisory for slight play in the nearside lower arm ball joint and some slight play in the offside anti roll bar linkage. The van was constantly banging when going over bumps which I know is usually a sign of a worn out drop link. He couldn't fault it as although it was banging, he still only found slight play.
I have replaced both the lower arm and the offside drop link but sadly the banging is still there! It doesn't always do it, but if I go over a speed bump, sometimes it will bang from the left and sometimes from the right. If I go over a manhole cover with just one wheel, sometimes it won't bang, sometimes it will.
If I was to engage 1st or 2nd gear sharply (by sharply I mean coming up to the biting point quickly) I get a loud bang from the nearside. If I bring the clutch up slowly and rev it a bit higher this doesn't happen.
It didn't get any advisories on any bushes (I.E. Anti roll bar) I've checked the lower engine mount and that's solid. I've checked all the bolts and they are all tight, the ball joint in the new arm looks to be as deep as it will go.
Anyone have any ideas on what else I should check? 2000 2.0 Litre HDi 800LBS
