  • 16 Vote(s) - 2.44 Average
Worn top mounts maybe???
The issue is this.
If moving slowly say in traffic and the brake is applied quickly and sharply, there is a knock noise and the feel of some sort of play in the front of the van.
I have had droplinks and wishbones replaced and everything is fully tight.
I thought it might be play in the suspension strut somewhere. Has anyone got anymore pointers
(17-12-2011, 01:54 PM)800HDI Wrote:  The issue is this.
i have just recently found the cause of my knocking after looking for it a thousand times.i had the front springs replaced after one had snapped.i found the clown that had done it had not seated the bottom of the suspension leg correctly the little lug should be between the clamp bolt.this resulted in the top of the suspension leg banging on the inner wing on both sides.since seating them i have no knocking.i never thought to check after a so called mechanic had fitted the springs!!!
it may be worth checking the work you have already had done !
(18-12-2011, 09:10 AM)lorraine Wrote:  i never thought to check after a so called mechanic had fitted the springs!!!
Mechanics !!!!! I have s**t 'em !!!!!
All work done ok as did it all myself lol.
May have to get out in the snow and start looking
Worn wishbone bushes. Had a breaker bar on the wheel nut today and found the strut moved left to right about 5 mm.
So called good quality cheap replacent wishbones from ebay. Never again, 16 months old with 9k miles on them.
Been bitten by getting cheap parts!!!
Users browsing this thread: 2 Guest(s)
Side Light Bulb Holder
14-01-2026 07:58 PM
ASDA AdBlue 10 January 2026
13-01-2026 07:04 AM
Last Post: andy@andymcm.com
12-01-2026 01:47 PM
» Replies: 24
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
