Tricky situation. What to do re mechanic.
Hi all, it is a good few years since I last logged in. Ive been checking in via facebook.
I'm a bit stuck.
I have a mechanic that I trust and has looked after the 2 Berlingos that Ive had for probably 9 years.  Never over charged etc  Im not asking about the fault here but the position im in with the garage and where responsibility lies.  Hope someone has a clue because im worried.
I booked my 2008 petrol multispace in for MOT. Mechanic asked whether my brakes had been cutting out. They hadn't. He said the brake cylinder had gone. It failed MOT, they replaced the cylinder, it then passed MOT. but as mechanic was on the way back from the MOT place, the brake pedal worked to stop the car but wont come back up...
They have had my car for 9 days now and been unable to fix it, im self employed, I neeed it!
All I know is that they cannot get this pedal to come back up. Hes admitted that he is stumped. Hes been on the forums, possibly this one, and rung other garages. Hes been unable to solve this problem. They know Berlingos well and havent had this happen before but have since heard it can happen after a cylinder change.
It's a tricky situation. This garage has always been trustworthy but i dont know what to do from here. Its not like i took it in to have the brakes fixed, I took it for mot.  this problem happened after they changed the cylinder. I don't want to be hit with a big bill or an undrivable car for something that happened there.
Contact has been sporadic, i know they are busy. He just said he'd call when he has good news. I  am getting seriously fed up now because of my work etc
I dont know what my next move should be. Any advice gratefully accepted, thanks
Hi Thora, This could happen to anyone but if it failed the mot, you had to get it repaired or you can't drive it anyway. A sticking brake pedal could be the pedal return spring (helper spring) or a faulty pilot seal in the new cylinder, a faulty pilot seal in the master cylinder or a blocked outlet on the reservoir - though the most common issue (suggest to them) is a rusty mounting clamp on a Flexi hose, causing it to pinch the hose and hold the pressure. Much less force is available to return the fluid than to push it into the cylinder. Ask them to check it isn't the flexi hoses being crimped by a rusted mounting bracket. I'd ask if they can provide a courtesy car as it is not your fault they have not found the cause yet, and the lack of your car is causing you to lose work and income. Everyone has to call time eventually so you're entitled to a reasonable estimate of how long this will take. They of course will not know, but this can't drag on forever. If they give you further smoke and mirrors on when it will be fixed, I'd let them know this is becoming unacceptable and your next stop will be trading standards or to get the AA involved to carry out a vehicle inspection on your behalf.
[-] The following 2 users say Thank You to Sol for this post:
  • Mike, ThoraB
This is just a thought but it could be a collapsed flex hose if they used a clamp or mole grips to stop fluid lose when they did the wheel cylinder. As Zion says not letting fluid return.
[-] The following 2 users say Thank You to Tomcat3 for this post:
  • Art b, ThoraB
I've never heard of a "pilot seal" but in a two stage master cylinder you should retain some braking if one seal goes but the pedal would have a lot of travel which would be obvious to an experienced mechanic. As you say cylinder I am guessing it's a rear brake and they can be a pain to bleed at the rear I'd go with the pedal spring and probably some air still in the system
  • ThoraB
I do feel sorry for the guy, it's a nightmare for him. If it was a garage i didn't know, i might be steaming in there. That is what makes it difficult in a way.
He has his regular work to do, which means Im seeing my car sat there with nothing being done. Frustrating for both of us. I'll tell him what youve said, which might be a tad annoying coming from me but I'll take the chance!
2001 Silver Multispace 1.9D
If at first you don't succeed, destroy all evidence that you ever tried!
Nice to be back on the forum. Thank you all
[-] The following 1 user says Thank You to ThoraB for this post:
  • Art b
(07-03-2020, 08:21 AM)ffrenchie Wrote:  I've never heard of a "pilot seal" but in a two stage master cylinder you should retain some braking if one seal goes but the pedal would have a lot of travel which would be obvious to an experienced mechanic. As you say cylinder I am guessing it's a rear brake and they can be a pain to bleed at the rear I'd go with the pedal spring and probably some air still in the system
Hi Frenchie, when I say pilot seal I'm going on industrial hydraulics experience, a pilot valve is a shuttle valve which is very similar to a master cylinder piston. One of the 2 seals on them can slip over the groove or swell and cause it to stick, even if it produces pressure when pushed. Ive had it happen on a rover sdi years ago when the wrong brake fluid was used that swelled the cylinder seals so the began to stick but still kind of worked for a while. When I pulled the master cylinder off, the piston had one seal that had flipped inside out.
Still nothing...
Have they checked any of the things we mentioned? Did they check the return spring has not popped off or broken either? Can you lift the pedal up easily by hand or is it stuck there?
One thing after another
Today 10:56 AM
Today 08:44 AM
12-11-2026 10:15 AM
Last Post: Dyane6
02-11-2026 11:10 PM
