Driveshaft bolt
Hi, I have 2010 Peugeot Partner aka Berlingo B9. One of the three driveshaft to gearbox housing bolts had a helicoil in it which has failed. I am wanting to now use a tapsert https://www.powercoil.com.au/pdf/Tapsert...19_EUR.pdf but have very little clearance to get a drill in and ream the hole to the appropriate size unless I remove the driveshaft and engine mount. Anyone have any ideas? Thankyou.
Not seen the job in the flesh so pardon if way off beam ( M59 owner )
Borrow a 90 degree angle drill ?
Shorten a drill bit ?
10-11-2026 08:36 AM
» Replies: 15
Last Post: Dyane6
02-11-2026 11:10 PM
Last Post: Drantanborg
31-10-2026 03:59 PM
24-10-2026 08:09 PM
