Felt Window channel?
Threads: 75
Thanks Received: 1,302 in 1,140 posts
Thanks Given: 223
163
07-03-2020, 02:36 PM
Anyone know if you can get a replacement felt lined window channel insert for the front vertical runner of the driver's door? The felt has worn away on the outer side and the window squeals like a pig when it's dry.
Threads: 9
Thanks Received: 441 in 402 posts
Thanks Given: 316
15
You should be able to get it from a dealer
Threads: 75
Thanks Given: 223
163
Cheers Polar, I guess after looking closely it's the full seal I'll have to change but may not be too hard to swap? Never tried to pull a channel seal out before. I'll check on servicebox.
Threads: 23
Thanks Given: 46
5
As a temporary measure have you tried rubbing a bit of candle wax where it binds
The following 1 user says Thank You to Trevor for this post:1 user says Thank You to Trevor for this post
• Sol
Threads: 75
Thanks Given: 223
163
08-03-2020, 05:50 PM
(This post was last modified: 08-03-2020, 05:56 PM by Sol.)
I haven't mate, that's a good idea. I've used silicon spray but it dries out over time. I forgot about candle wax being used for brass screws by chippies, well worth a try. Cheers.
I priced a new one, £145 so a bit dear. Not that I can't afford it but it sticks in the craw replacing something that works but just squeaks. I'll try paring down a candle till it fits in the channel and try rubbing a coating down it.
On a slightly different tack, does anyone else who became a donator notice they suddenly couldn't click thread links in an existing post, or view profiles? Apollo has been trying to fix my profile but now I get adverts all over the place again, can view profiles but not click embedded thread links.
Threads: 41
Thanks Given: 82
6
(08-03-2020, 05:50 PM)Zion Wrote: I haven't mate, that's a good idea. I've used silicon spray but it dries out over time. I forgot about candle wax being used for brass screws by chippies, well worth a try. Cheers.
Not heard anyone else mention that before, but I'd have thought you would all have the same issue with links etc. Is it all links or certain ones?
Threads: 75
Thanks Given: 223
163
It's any thread that is linked in an existing thread, like when someone says see my original thread here: link etc - it says you are banned or not authorized to view this page. Also I couldn't view anyone's profile. Now Jacob has kind of fixed it but adverts have returned with a vengeance and still can't view thread links. Can view profiles though.
Thanks Given: 188
23
It happens to me, when im logged in and there is a picture attached if I click on the picture it then says im not authorised to view image and have to login. Very odd.
Are we there yet?????
Threads: 23
Thanks Given: 46
5
If I log in I cannot see other users details by clicking on their name. If however I do not log in I see it all with no problems
Also if I report a spam post by clicking the Report button my system just freezes up.
Threads: 75
Thanks Given: 223
163
Yeah I used to be able to report spam posts but now I get an error when I try. This must be a wider problem than I thought. I did think it was just me.
valeo alternator CL15 rebuild
Yesterday 07:08 PM
Unusual Braking Problem
Yesterday 06:33 PM
Yesterday 06:19 PM
oil Sump
Yesterday 06:18 PM
5 x 18" wheels suit B9
Last Post: raymondinio
Yesterday 04:34 PM
M59 1.4 Petrol question
14-03-2025 10:48 PM
14-03-2025 09:29 PM
» Replies: 27
14-03-2025 09:08 AM
Insurance Shocker !!!
14-03-2025 09:04 AM
13-03-2025 08:09 PM
