Threads: 56
Thanks Received: 19 in 19 posts
Thanks Given: 7
4
hi all, i have berlingo forte 1.9d 03 model ,how much play should there be on the connection between the gearstick and the gearshift rod ,the three rods at the other end of the gearshift rod are quite stable ,well no play !! and my gearstick is quite floppy ,any input would be much appreciated , thanks in advance
nice to be important,more important to be nice
my ride is a berlingo forte 1.9d 2003 model in pukey blue
Threads: 2
Not sure if this is your problem but our gearstick was all over the place and almost impossible to select a gear. Had the rubber bushes replaced and like new. Don't think it was a big job.
Threads: 7
Thanks Received: 2 in 2 posts
Mine was playing up and finally threw one of the linkages behind the engine, had t replace them all.
Threads: 41
Thanks Received: 42 in 37 posts
Thanks Given: 3
i had the same problem (floppy vauge gearstick ) i replaced the 3 linkage rods brouht from ebay and all was nice and tight again.
