13-03-2020, 03:59 PM
Hi All,
First of all - THE ADBLUE TANK WAS FULL!
I have been scunnered three times now on the Urea light not going out and doing the annoying countdown from 750 miles. Dealer does not want to know and anyway, can't do anything for three weeks as has no slots (2nd time of happening - same at next nearest). Local garage changed the Nox sensor (RAC warranty) and was ok for a while but after driving for 50 miles at a shot, the engine warning and urea lights came on and the countdown started.
First time, no countdown started but resetting using a £10 reset box worked, second time, wee box did not work. Countdown started. Found an engine remap guy and he fixed it with a professional box. He was stumped at first but then he worked it out that there are two sensors which need synching. As so as they did, it cleared the Urea light and countdown. He mentioned the system calculates how much ADBLUE is in the system. The numbers used in this calculation can be adjusted and this he did.
There is still a query about the float switrch in the ADBLUE not working and this is a pricey fix - new tank is £1k they say. It may be possible to whack the tack with a rubber hammer to free it and so I shall be getting one.
I hope this helps some confused soul who may end up being prey to this immature technology. I'm totally pro the eco thing but if it causes this sort of crap.....
Replies on this welcome, even if it's to tell me I'm wrong. :-D
Best to you's all!
Maximan.
Best to you's all!
Maximan.
