Thanks Given: 1
14-03-2020, 09:18 PM
(This post was last modified: 14-03-2020, 09:25 PM by JOEHHT.)
Does anyone have the part number for the heater blower relay (green one) please?
Berlingo van 2010.
The previous keeper has replaced the relay but it isn't the correct one so I don't have the old one to reference against.
The resistor, blower & switches work perfectly if I bypass the relay so it's definitely the wrong one fitted.
Threads: 123
Thanks Given: 250
34
If you try catcar.info or service.citroen.com you can use your VIN to find the right part numbers.
The following 1 user says Thank You to cancunia for this post:1 user says Thank You to cancunia for this post
• JOEHHT
Threads: 123
Thanks Given: 250
34
I think that both sites will work directly on the VIN, both sites will also allow you to go to the Peugeot spares section.
Threads: 75
Thanks Received: 1,306 in 1,140 posts
Thanks Given: 223
164
Service.citroen.com now want a fortune for a subscription to view anything but the handbook. Used to be able to view diagrams and part numbers but no more. This is very recent cos I was using it 3 weeks ago.
