Threads: 123
Thanks Given: 250
34
One of the bonded windows has a leak from the top so that when it rains a small amount of water gets in. The gap between the window & the car body is too small to get a silicone nozzle into so I was wondering if anyone can suggest a suitable liquid type glue or sealer that I can pour into the gap between glass & bodywork to seal the leak?
Threads: 13
Thanks Given: 61
4
Captain Tolley's Creeping Crack Cure
https://www.amazon.co.uk/Captain-Tolleys...B003T6EJ9A works well on fine gaps on boat windows so should do the job nicely.
Threads: 13
Thanks Given: 61
4
It is very viscous and would have no problem in running into the area you describe. It can be applied in layers so would build up to a good seal. As said I have used it very successfully on sailing yacht windows which are subject to a fair amount of water being sluiced over them.
Threads: 123
Thanks Given: 250
34
16-03-2020, 12:54 PM
(This post was last modified: 16-03-2020, 12:55 PM by cancunia.)
Righto, I've ordered some Captain Tolley's and will get a syringe with tube to go behind the window. With the trim off the inside, I'm fairly sure I can see where it's leaking. I did ask a local windscreen co about getting it re bonded & was told it'll be £75 + VAT so it'll be Captain Tolley or a large amount of sealer into the gap.
Threads: 123
Thanks Given: 250
34
A quick update, success!
It took a lot of small doses over several days to get the leak sealed. I'm not sure if it was coincidence but I finally got it sealed when the weather warmed up. To get behind the glass I used a short piece of tube cut from a cleaning spray bottle, it fitted very neatly on the end of the sealant nozzle.
Threads: 75
Thanks Given: 223
164
Nice one mate, good to see a successful fix.
