Hi
Just bought a 2009 Multispace last weekend. It has 120000 km, or a bit under 75k miles on the clock. Anyway... It started fine multiple times when I took it for a test drive before buying it. Fueled up during my drive home, and it started right away with no problems. But then, after it had sat for a couple of days here at home it wouldn't start. I heard clicking sounds when I turned the key, but the engine didn't turn over. Was in a rush to get the kids to school, so just took our other car instead.
After work, I checked the battery with my multimeter. 6.44V. No wonder the car didn't start!
![[Image: attachment.php?aid=5046]](https://www.berlingoforum.com/attachment.php?aid=5046)
Tried to hook up my charger. Didn't even register that it was connected to a battery, so no luck charging it
![[Image: attachment.php?aid=5047]](https://www.berlingoforum.com/attachment.php?aid=5047)
That's how I tried to hook up my charger, but no lights turned on, so no charging.
Next up I tried to jump start it using my other car. Hooked up the jumper cables the same was as I hooked up the charger in the photo above. Again measuring with my multimeter I got a bit over 12 V on the battery. But the car still wouldn't start!
![[Image: attachment.php?aid=5048]](https://www.berlingoforum.com/attachment.php?aid=5048)
Out of ideas I gave up for the time being. A day later I got another idea to try. If I hooked up the battery to my other car with my jumper cables, maybe I could get my charger working.
![[Image: attachment.php?aid=5049]](https://www.berlingoforum.com/attachment.php?aid=5049)
It worked!
![[Image: attachment.php?aid=5050]](https://www.berlingoforum.com/attachment.php?aid=5050)
That was yesterday. Left it charging overnight, and today when I went out to check on it my battery was up to a bit over 12 V, and the car started again! Yay!
Checked again with the car running, and the alternator seems to be working, got a reading of about 14.4 V on the battery with the engine running.
So, two questions.
1. Why didn't the car start off of the jumper cables?
2. What the heck happened? Why was the battery down to just 6.44 V? How do I make sure it doesn't happen again?
(I guess technically that might have been more than two questions
Thanks for any input!
It worked!
So, two questions.
)Thanks for any input!
