Hi there the abs and traction control lights keep comming up on my Citroen berlingo 2014 and when plugged into a diagnostics tester nothing comes up. Can anyone give me any advice please many thanks
Thanks Given: 188
23
Hi Alex welcome to the forum. What diagnostics kit were you using unless it was the citroen/Peugeot kit or a really decent 3rd party kit they cannot read abs/traction control faults as far as im aware.
Are we there yet?????
Is a snap on diagnosis tester
Threads: 75
Thanks Received: 1,310 in 1,140 posts
Thanks Given: 223
164
Have you checked the brake fluid level is correct first? TC is correct, you need pretty specialised kit to check these vehicles properly. It could just be fluid level however.
Always possible you have an actual abs fault, but you don't say if the large red STOP warning comes up? If there was a genuine fault, that would happen for the brakes / abs system.
Threads: 13
Thanks Received: 139 in 113 posts
Thanks Given: 162
18
Hi,
You will need lexia to read codes.
Full ABS codes is best read by lexia.
Best regards,
brajomobil
Threads: 12
Thanks Received: 386 in 274 posts
Thanks Given: 16
37
30-03-2020, 08:18 PM
(This post was last modified: 30-03-2020, 08:18 PM by Lighty.)
Brake fluid level is a good shout.
ABS will only show a fault when the light is on, so wait for the light to come on & test the car in this state , without switching the engine off, often the fault will simply reset once you switch off.
The following 1 user says Thank You to Lighty for this post:1 user says Thank You to Lighty for this post
• Sol
Threads: 75
Thanks Given: 223
164
(30-03-2020, 08:18 PM)Lighty Wrote: Brake fluid level is a good shout.
Cheers Mark. I've seen this happen before and when the stop light doesn't come on, it was only low fluid level.
