AC Compressor
Hi,
I'm trying to find a replacement AC compressor for 2001 Berlingo, mines suffering with bearing failure and getting really noisy. I've looked all over the internet using car reg but they all seem different. The details on mine are Sanden SD6V12 Model 1431F
Anyone had to replace one of these and any ideas on compatible part numbers?
Ed
You could try putting your VIN into catcar.info under the Citroen area of the site. From that you can get a part number which can be used to search online.
Thumbs Up
(01-04-2020, 05:40 PM)cancunia Wrote:  You could try putting your VIN into catcar.info under the Citroen area of the site. From that you can get a part number which can be used to search online.
Thanks will give that a try.
Here's a second hand one google found.
(02-04-2020, 08:51 AM)ffrenchie Wrote:  Here's a second hand one google found.
Thanks, it's nearly the right part but the mounting brackets are different on mine.
I found a really good Citroen Peugeot specialist, Martin Morgan in Torquay. I didn't want to spend loads of money on a replacement compressor, he had a quick look and was able to fit a shorter belt to bypass the AC compressor. Result! So I can confirm that you can bypass the ac compressor on a 2001 1.6 16v petrol engine Berlingo.
Martin also had a look to and found the pulley separately from the compressor in case I want to get the AC going again. Might look into it later, see how the little van gets on for now.
[-] The following 1 user says Thank You to Ed_Forte for this post:
  • cancunia
04-11-2026 11:37 PM
Last Post: Drantanborg
31-10-2026 03:59 PM
24-10-2026 08:09 PM
20-10-2026 06:45 PM
» Replies: 45
18-10-2026 06:46 AM
» Replies: 82
17-10-2026 05:41 PM
