[Engine] Question about Injectors?
Hello, I have a leaky injector problem on my 2008 1.6Hdi Berlingo Multispace.
Looking online there seems to be a multitude of seal kits for this engine [I'm probably going to go for a genuine replacement kit on these, unless anyone can recommend a good aftermarket kit?] but are all the seals the same for different versions of the 1.6Hdi engine? Looking online there seems to be different thicknesses of the copper sealing washer and when I've checked for compatibility for my vehicle it seems that most kits are only for the 1.6Hdi 75 and not the 1.6Hdi 90?
Looking at the VIN code for my vehicle it appears to be a DV6ATED4/9HX engine?
Thanks for any help.
Hi, as far as I know, the 75 and 90 HDi only differ by ECU software. Everything else is identical.. Is your vehicle the B9 shape as the years overlap at 2008.
Have you checked the parts for your vehicle on http://www.catcar.info ?
Select English, select Citroen, then enter your vin there, and drill down to fuel system etc, the seals will be listed with OEM part numbers. As far as engine parts go, I've found it best to stick to original equipment.
  • Multispacer
(02-04-2020, 10:56 PM)Zion Wrote:  Hi, as far as I know, the 75 and 90 HDi only differ by ECU software. Everything else is identical.. Is your vehicle the B9 shape as the years overlap at 2008.
Thanks for the link to the info.
One thing after another
Yesterday 05:02 PM
Yesterday 10:41 AM
» Replies: 16
Yesterday 10:15 AM
Last Post: Dyane6
02-11-2026 11:10 PM
