03-04-2020, 01:51 AM
Hi there
My dads Berlingo came in for the brakes to get done. I changed the front discs and pads and rear wheel cylinders as they were P*ssing brake fluid out. After we bled them there was no brake pedal what so ever. The stop light was flashing the first time despite the break fluid being full so i suspect there was an air lock, So we bled them again and we got a bit of a pedal but to be frank it was Sh"te and would have been lethal to Drive. We then attempted to bleed it with an woeful pressure bleeder but it just sprayed brake fluid everywhere out the cap. So we changed the master cylinder and after bleeding through the master cylinder ABS pump, Front and rear brakes there was no pedal what so ever. The next day we opened the rear bleed nipples and let them drip for an hour. This brought back some what of a pedal but it was still P*sh.
I have now since ordered a proper gunsons eezibleeder to try and bring the Pedal back before condemning the ABS Pump how ever for some reason my dads berlingo doesn't have a load sensing valve.
The Van its self is a 2007 600 Enterprise Van withe the 1.6 HDI 16v 75hp DV6BUTED4 engine.
What i'm wondering is did all the m59s have load sensing valves or did some not as on my dads there is no evidence of a load sensing valve being fitted and no brake lines going to one that would suggest its existence.
Is there supposed to be one?
