Rear tyre wear
Threads: 4
Thanks Received: 2 in 2 posts
Thanks Given: 4
Hello folks.
Has anybody found a definite reason / cure for the excessive outer edge wear on the rest tyres? I have a 2012 model.
Threads: 75
Thanks Received: 1,299 in 1,139 posts
Thanks Given: 223
163
Have you had the rear tracking and alignment checked? You could have worn rear bushes leading to interesting camber angles.
Threads: 28
Thanks Given: 78
Have a look here,
https://r.tapatalk.com/shareLink/topic?u...source=app
08 B9 odd rear tyre wear
Mark
Sent from my motorola one vision using Tapatalk
Threads: 4
Thanks Given: 4
(03-04-2020, 07:04 AM)Zion Wrote: Have you had the rear tracking and alignment checked? You could have worn rear bushes leading to interesting camber angles.
No not yet. I am planning to find a place.
Seems strange that both wear on the outer edge, They can't both be toeing in? The bushes appear good.
Threads: 75
Thanks Given: 223
163
Not toe, but camber. Could be either really. Try the high pressure solutions put up by others and see what happens? If it's pressure related, that suggests the standard pressures are not enough to overcome the built in camber of the rear suspension setup, but I'd be interested in what alignment is found on a laser rig.
Threads: 75
Thanks Given: 223
163
05-04-2020, 08:59 AM
(This post was last modified: 05-04-2020, 09:01 AM by Sol.)
My point about camber, is that if you do a lot of miles with an empty van and get outer edge wear, it could be the vans have negative camber so that the wheels sit straight up and down when fully loaded. Might be like this empty \ / (cambered out at the top - exaggerated)
Threads: 2
Thanks Given: 2
(05-04-2020, 08:59 AM)Zion Wrote: My point about camber, is that if you do a lot of miles with an empty van and get outer edge wear, it could be the vans have negative camber so that the wheels sit straight up and down when fully loaded. Might be like this empty \ / (cambered out at the top - exaggerated)
Yep exactly, nothing can be done about it other than slinging a few bags of cement in the back !
63 XTR 1.6 HDR 115 64000m
Threads: 12
Thanks Received: 28 in 23 posts
Thanks Given: 1
(05-04-2020, 01:48 PM)Oldskool Wrote: (05-04-2020, 08:59 AM)Zion Wrote: My point about camber, is that if you do a lot of miles with an empty van and get outer edge wear, it could be the vans have negative camber so that the wheels sit straight up and down when fully loaded. Might be like this empty \ / (cambered out at the top - exaggerated)
Another solution is bought a comper kit and left all time in Berlingo.
I did and edge wear gone.
Vigo, The cradle of all Berlingos / Partners.
Threads: 12
Thanks Given: 1
(05-04-2020, 01:56 PM)NANO_Vigo Wrote: (05-04-2020, 01:48 PM)Oldskool Wrote: (05-04-2020, 08:59 AM)Zion Wrote: My point about camber, is that if you do a lot of miles with an empty van and get outer edge wear, it could be the vans have negative camber so that the wheels sit straight up and down when fully loaded. Might be like this empty \ / (cambered out at the top - exaggerated)
Another solution is bought a camper kit and left all time in Berlingo.
Threads: 12
Thanks Received: 386 in 274 posts
Thanks Given: 16
37
We have recently invested in a Hunter Alignment set up .
All Berlingo’s seem to suffer from this issue.
When I was on the training course at Proalign, the resident alignment genius assured me you could buy shims to alter the rear stub axles on just about everything.
Yesterday 04:48 PM
Last Post: BrianS
Yesterday 01:58 PM
» Replies: 24
Drop in fuel economy
Last Post: Andhall
Yesterday 09:21 AM
Not able to register
Last Post: Mike
22-01-2025 11:03 PM
2011 B9 DPF warning light
22-01-2025 10:51 PM
Last Post: Matt Haigh
22-01-2025 07:21 PM
M59 rear wheel splay...
21-01-2025 03:27 PM
Indicator/lights Stalk
Last Post: magoo1
21-01-2025 03:09 PM
Last Post: pondweed
21-01-2025 01:21 PM
21-01-2025 12:41 PM
