[Transmission] Does any one know where i can get a reluctor ring?
Need to change the reluctor ring on my dads 600 enterprise van as the Cv joint has rusted causing the ring to swell or i've been a diddy and damaged it when putting the ball joint back into place. It also took the 3 month old wheel speed senor with it as well but i've got another waiting to go into it.
The ring its self is the 48 tooth ladder type ring but i can seem to find one that is compatible with his van as there all for the B9 berlingo.
Where can i get an individual reluctor ring or how much is it for a whole drive shaft as i don't mind changing it if its a reasonable price.
Cheers.
Buy a service exchange unit from the local motor factors
  • IHateMyDadsM59Berlingo
Try searching on the net,  for instance amazon has drive shafts complete with 2 cv joints  from about £25 on.
I gat one a couple of years ago from ebay and no bother with it , easier fitting the whole thing rather than fitting a new cv joint to a shaft
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
Also worth getting the Autodoc app, plenty of parts at discounted prices. Look on Google play.
Does anyone know if the DW10 driveshafts for the M59 Have a ladder type ring with 48 teeth, if so are they compatible with the DV6BUTED4 600 enterprise van gearbox?
Yesterday 08:03 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
16-09-2026 09:50 AM
» Replies: 16
removing front strut
16-09-2026 02:07 AM
Strut Top Mounts
15-09-2026 07:58 PM
