B9 Service Manuals - click to download
Threads: 75
Thanks Given: 223
164
07-04-2020, 09:39 AM
(This post was last modified: 07-04-2020, 11:29 AM by Sol.)
Hi folks, I found this link to the full B9 manuals and it works, not sure if others knew about it but was well buried. The file is a zip, inside are *.mht files which normally are associated with Internet Explorer but these only open in MSWord - you may be able to open them with something else, but they are proper Citroen data sheets and look pretty good. Link works, downloaded them just a minute ago. I found they work just fine if you have MS Word, and you could then save as PDF etc.
I am using my "work from home" laptop which has Industrial grade antivirus and it did not flag any issues when the file was downloaded and unpacked. Once unpacked to a folder, right click and select "open with" then choose MS Word or even Wordpad if you don't have it (not tried WP but MS Word works) - please note the default of Internet Explorer only shows a blank file - it can't be used to open these files. This seems to be an addressing issue with IE and not a problem with the files.
I also note it was uploaded 2011 so some items may not be identical if you have a much later vehicle, but better than nowt eh!
http://www.mediafire.com/file/z91yqo1t9w...9.zip/file
Threads: 10
Thanks Received: 11 in 6 posts
Thanks Given: 10
4
Cheers buddy!!
2015 Berlingo Enterprise 1.6 HDi
Threads: 75
Thanks Given: 223
164
You are welcome mate
Threads: 123
Thanks Given: 250
34
Threads: 75
Thanks Given: 223
164
Cheers mate.
Threads: 2
Thanks Received: 15 in 15 posts
Thanks Given: 1
(07-04-2020, 09:39 AM)Zion Wrote: - please note the default of Internet Explorer only shows a blank file - it can't be used to open these files. This seems to be an addressing issue with IE and not a problem with the files.
Hello Zion,
Looks like original Citroen information via LEXIA if you have an online account.
*.mht files opened automatically with default Internet Explorer IE11 under WIN7-32bit with no problem.
Regards Rolf
_______
Berlingo Blue HDI120 S&S Shine, 08/2016, KYANOS Blue Metallic
Threads: 75
Thanks Given: 223
164
Thanks Rolf, good info. My IE would not open them but MS Word did. For others who may also have this issue with the files.
Threads: 26
Thanks Received: 32 in 29 posts
Thanks Given: 9
10
05-03-2023, 06:40 PM
(This post was last modified: 05-03-2023, 06:42 PM by smutts.)
A belated thank you, plenty of usefulness for my M59 with the 16v DV6.
The files open fine with Brave browser, but you just can't scroll.
So "print webpage as PDF" and I can now be allowed to try to fix my own property.
Don't get me started on right to fix. (DIY? destroy it yourself  )
The online paywalled main dealer only service manuals & diagnostics will send me mad.
227,00 miles, (Resurrected at 186,000)
Threads: 75
Thanks Given: 223
164
Ah yes, so what to do is get the VM version of ServiceBox on eBay. Then run it on VMWare Player, and you have all electrical schematics and repair procedures for any Citroen up to 2013. Install CutePDF for windows XP on the VM itself (create shared folder) then you can print all diagrams or procedures from ServiceBox as and when you like.
Threads: 26
Thanks Given: 9
10
Hi Ho! Hi Ho!
It's off to Fleabay I go!
VmWare is already installed,
Hi Ho! Hi Ho! .etc
Last Post: BigVtwin996
Yesterday 12:10 PM
Eolys replacement tank
Last Post: jw4821
Yesterday 11:40 AM
Warranty on parts
07-08-2026 04:17 PM
Ahh bless them...
06-08-2026 02:28 PM
06-08-2026 07:34 AM
06-08-2026 01:45 AM
05-08-2026 09:15 PM
Strange whining noise
05-08-2026 04:28 PM
Check this one out guys
04-08-2026 10:01 PM
04-08-2026 11:30 AM
