19-12-2011, 01:35 AM
(This post was last modified: 19-12-2011, 01:36 AM by overs10ded.)
My wife has a 2003 Berlingo Multispace that she bought new from the dealership here in Costa Rica. A pretty good car! However now w/ 167,000 kilometers, the clutch is having a occasional hick-up where the clutch pedal will "jump" or jerk and most times the clutch will operate normally but the pedal travel and release is much closer to the floor with on rare occasion that the clutch does not disengage fully. However a toe under the pedal or side-stepping the pedal and it will pop back and "reset" itself. This morning I took out the battery box and looked over the entire cable from the pedal to the throw-out arm and couldn't find any obvious problem. Of course I couldn't duplicate the problem at the time. Could it be in the throw-out bearing/fork inside at the clutch diaphragm? The end at the pedal seemed good (plastic piece).
Also we paid to have the fuel pump rebuilt and now it doesn't make the power that it used to. Is there an adjustment that I can tweak to add fuel? There is no smoke what soever and used to puff a little when she made good power!
Thanks for any help! Good times!!!
