Mk1 berlingo indicator problwm
Hi
I have a 750 hdi 1.6 2011 berlingo
Just started having trouble with the front left indicator occasionally it works for 2 seconds then stops and does that fast blink thing. Then after the first attempt it wont even work for 2 seconds it just faat blinks the rear indicator and the little one on the front wing. Is this a relay or stalk or bulb problem any ideas thanks
Change the front bulb it sounds like it's defective.
I maybe wrong, but the bulbs sound like the best place to start..
(12-04-2020, 04:35 PM)Brixmis7 Wrote:  I maybe wrong, but the bulbs sound like the best place to start..
Ok thanks I did take it out to have a look but it seemed.ok I will try a  ew one tomorrow
You need to see the bulb working. Sometimes the filament looks intact but is burnt out. A fast repeating indicator can can be caused by a blown bulb.
Absolutely correct. Unless the holder is corroded - could be connection to the bulb if not a blown bulb. But as others said, that's the No1 reason.
Well today I quickly swapped bulbs and hey presto it works. Thanks all who helped
Thumbs Up
Thanks for posting the result.
Good stuff mate.
06-10-2026 04:12 PM
06-10-2026 12:46 PM
06-10-2026 10:00 AM
Last Post: RMSSA
22-09-2026 08:52 AM
Turbo lag 1.6HDi
Last Post: Westy
21-09-2026 09:07 AM
removing front strut
16-09-2026 02:07 AM
