Mysterious wire
Hi guys I've just bought a 55 plate 1.9 diesel van. And I've notice a wire hanging just next to the brake top up, and I can't find where it should be plugged into. I've attached a photo can anyone help cheers Gav
Attached Files Thumbnail(s)
Hi Gav welcome to the forum, from memory of other threads I think your mystery wire connector is surplus and not needed on your model/spec van. Others have found this wire hanging down the bulkhead. If there is nothing nearby that it can plug into I would just clip it up out of harms way.
I think that was meant for vans with the brake fluid level switch in the reservoir..
Could be wrong but i thing its a connector used on the DV6 vans but i cant remember what but i do recognize it.
ignition lock ggrrrrrrrrr
Last Post: Sikez2012
Yesterday 10:07 PM
Engine Fan Running
Yesterday 09:59 PM
Bettery Issues - A Solution.
Yesterday 10:45 AM
Sound proofing windscreen
16-11-2025 02:43 PM
14-11-2025 07:34 AM
M59 unlocking itself
11-11-2025 09:33 PM
04-11-2025 09:48 PM
04-11-2025 09:15 PM
horn
03-11-2025 08:41 PM
How many miles
03-11-2025 08:12 PM
