28-04-2020, 09:40 PM
I have a new (July 2019 1.5D/130 Flair) Berlingo, it has done 5200 miles.
I have had issues with the stop start not working.
It seems the spring loaded +Ve battery terminal clip had worked it's way up and may have been intermittent.
If so could this have upset the BSI.
The stop/ go does not work at all all I get is 4 flashes from the s/ start green warning lamp.
If it may be the BSI is the reset EXACTLY as previous models is window open key ignition press button15 seconds, battery terminal off for 3mins etc
Thank you
Roger
Thank you
Roger
