Threads: 32
Thanks Received: 3 in 3 posts
Thanks Given: 18
I guess that’s what’s happened. Was thinking of doing a helicoil on the sump thread, but that might throw more problems up. Will keep an eye on it see if any leaks occur.
Threads: 3
Thanks Given: 2
Helicoil sounds a good idea to me, its the copper washer that seals the oil in, thinking the thread is just to keep pressure on it.. would be nervous of a loose sump plug, you could lose a lot oil at speed and not know until the oil light appears....
Threads: 13
Thanks Given: 61
4
Always replace the copper washers every time the sump plug is taken out.
Threads: 32
Thanks Given: 18
If I do the helicoil I think I would have to drop the sump in case any shavings get in to the oil. Going to check this morning see if it’s been dripping overnight
Ian
Threads: 123
Thanks Given: 250
34
It might be easier to get a used sump from eBay?
Threads: 32
Thanks Given: 18
Had a look about an hour ago, looks like it let loose a couple of drips on the cardboard I put under their. I had put a rubber washer under the copper seal when I refitted it yesterday before fitting, the washer looks like it hadn’t been changed in a while. I’ve ordered a new sump plug an copper washer. Going to drain and refit with new plug omitting the rubber washer, if it still leaks after that. The new or second hand Sump it is. Replacing the front springs today so plenty to keep me busy in the lockdown ?
Threads: 32
Thanks Given: 18
Now have a leaking Gearbox ?
Was renewing the broken spring NSF had pulled the strut towards me after loosening the bolts , the drive shaft came slightly out of the gearbox, think I lost about a pint of fluid. New spring is installed looks like the shaft went back ok, just need to get some gearbox oil to top up.
Ian
Threads: 43
Thanks Received: 415 in 372 posts
Thanks Given: 137
33
(30-04-2020, 09:51 AM)killie77 Wrote: Thanks
Ian
if a steel sump a magnet will catch the shavings , you can drag them to the drain hole and pull them straight out.
2020 Rifter 1.5 allure
2010 B9 red XTR w a v.
2001 1.9d DW8B white Berlingo
2005 2.l green Berlingo
berlingo 1.4 red multispace
1993 xud 1.9 red partner
