ECU pin out data
Hi I have a M59 1.6hdi berlingo van and I need some pin out data for the ecu, does anyone have the data that they could share?
(30-04-2020, 03:22 PM)Chris_wynn Wrote:  Hi I have a M59 1.6hdi berlingo van and I need some pin out data for the ecu, does anyone have the data that they could share?
The diagrams tend to be arranged by component, for example the injectors. Here's a diagram that I got from Sedre which shows a lot of the components attached to the engine / injection ECU. There's a key to the components here..
http://www.autoelectric.ru/auto/peugeot/...agrams.htm
.pdf   DW10 hdi injection & ECU Pinouts.pdf (Size: 341.54 KB / Downloads: 64)
Hi thank you for the info and pin outs, the positives and earths are referred to by a letter then a number is it easy to work out where they are when you look at the plugs?
(30-04-2020, 08:41 PM)Chris_wynn Wrote:  Hi thank you for the info and pin outs, the positives and earths are referred to by a letter then a number is it easy to work out where they are when you look at the plugs?
The pins should be numbered on the plugs, or at least the first & last.
IIRC, the letters & numbers in the boxes refer to the pin position & row, but I may be wrong about that. The plugs are identified by the colour & number of pins, so 32V NR = 32 Pin Black (Noir)
Leaking windscreen or aerial
15-04-2026 08:50 PM
Apple Carplay
02-04-2026 01:26 PM
