Leisure Battery Connection
Hi
I am fitting a leisure battery to my 2015 Multispace and have a question about the actual connection to the main vehicle battery.
Is it acceptable to use the spare fuse way on the battery top power distribution panel or it there a better option?
TIA.
borism11
Attached Files Thumbnail(s)
Looks like an ideal place to connect to. Maybe a lower value fuse behind it would be a good idea.
  • Art b
(09-05-2020, 07:24 AM)cancunia Wrote:  Looks like an ideal place to connect to. Maybe a lower value fuse behind it would be a good idea.
Thank you, that sounds like sound advice.
Would tend to fit a split charge relay - charges second battery while engine running - and wont drain main battery should you leave anything connected  to second battery -done same when refitted towing socket (with big thanks to Zen_speedmaster and others on forum)
do it the way most people do it [  explained by dadstaxi ].. run it from the +positive car battery via a fuse............doing it ur way will bring u problems!!!!!
07-04-2026 04:17 PM
Apple Carplay
02-04-2026 01:26 PM
Last Post: Transmit
02-04-2026 11:21 AM
