Won't start. Electrical problem?
Threads: 2
Thanks Received: 2 in 2 posts
Thanks Given: 7
Annoying problem with Berlingo, Maybe someone can help.
Patient: Berlingo 1.6 Petrol, 2005
I have a problem from time to time to start the car. It drives well, starts with no problem, no battery issues, however, from time to time car doesn't want to start at all (there is no symptom of low battery). At first, I thought it is the battery, but all electronics work, no problems with the lights or controls in any way.
When you turn the key in the ignition everything works but there is no sign of engine wanting to start and you cannot hear starter at all. Nothing happens. Recently I have noticed that when I shut the bonnet not being gentle, it did it again. The only thing that helps is a push start.
Is there any security feature that prevents the engine from starting?
Any ideas?
I have checked earth connections and restarted bsi.
It was starting fine until i have closed bonnet not being gentle. The same thing happened again. Everything is fine just the engine won't start. I can hear some clicking but no life.
Cleaned terminals on the battery too.
Have to push it again to start from gear and after that all back to normal.
Help please.
Sent from my ONE A2003 using Tapatalk
The following 1 user says Thank You to OrtesPL for this post:1 user says Thank You to OrtesPL for this post
• M59Dibba
Threads: 20
Thanks Given: 2,126
18
(13-05-2020, 07:49 PM)OrtesPLTo me it sounds like a starter feed,solenoid,or earthingproblem. Try tapping the starter next time& if it turns your problem is in this area. Wrote: Annoying problem with Berlingo, Maybe someone can help.
Any ideas?
Help please.
Strawberry flavoured windows
Threads: 2
Thanks Given: 7
I thought so, but when I push the car and start from gear it's fine after that and start every time untill another bonnet slam or when once it was in gear when started the engine - the same thing happened
Threads: 75
Thanks Given: 223
164
Your starter could be sticking as Ron says, or the ignition barrel is crumbling inside. If you hear rapid heavy clicking when trying to start, I'd suspect the starter motor and pre engagement solenoid first. If it's silent, try a replacement ignition barrel and key.
• OrtesPL
Threads: 29
Thanks Given: 67
20
Sounds like brushes sticking in the starter motor or a dead spot. Can you get to the starter to tap it with a hammer, don't beat it just gently tap the casing then try it on the key.
Threads: 2
Thanks Given: 7
Cheers. Will give it ago after work today
Threads: 75
Thanks Given: 223
164
The reason not to hit the starter hard, is that it's a permanent magnet motor and has huge magnets bonded to the inside of the casing. If you whack it, you can shatter the magnets. Once that happens, it's game over for that starter.
• OrtesPL
Threads: 2
Thanks Given: 7
I haven't done anything with the starter battery or even did not open the bonnet and the car started within seconds.
I just lef it overnight and voilà, it's alive!
It had sun shining on it, old battery problems?
I am puzzled
Threads: 2
Thanks Given: 7
(14-05-2020, 06:23 AM)Zion Wrote: Your starter could be sticking as Ron says, or the ignition barrel is crumbling inside. If you hear rapid heavy clicking when trying to start, I'd suspect the starter motor and pre engagement solenoid first. If it's silent, try a replacement ignition barrel and key. No noise, bo sound. Dead silent starter
Threads: 75
Thanks Given: 223
164
I'd maybe consider the ignition barrel internal switches to be an issue then. Dead batteries recover a small amount when left alone but not enough to be useable again without charging.
• OrtesPL
Today 12:33 PM
Last Post: Desdinova
08-09-2026 05:46 PM
07-09-2026 09:06 AM
Last Post: BDRichardson
06-09-2026 04:07 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
24-08-2026 07:58 PM
