DMF or Solid flywheel ? on 2010 Berlingo XTR
Hello again everyone. I've got a judder on the clutch that only presents itself after driving a while. When cold it doesn't do it only starts when warmed up and gets worse in start stop traffic. There seems to be plenty of meat on the clutch and its not slipping (done 51000 miles) The engine code  is  DV6DTED (9HP) JBCM3014558 and 5 speed gearbox and logbook says 68kw. I have done searches all over the place and some results say my car has solid flywheel and some say DMF. How can I find out for sure,   If its a DMF, can I get a conversion kit to a solid Flywheel. Nothing seems straight forward on getting the correct information. If it helps I can provide my VIN. I am doing this research now for when the day comes that I will need a new clutch Any help and advice would be much appreciated. Thanks, Dave Smile
My Car :- 2010 Citroen Berlingo XTR Multispace
You could ask a main dealer for a written quote for a new clutch, they should list the part number on the quote. Other than that, maybe Lighty will be able to find out.
  • Daveyboy999
(14-05-2020, 07:37 AM)cancunia Wrote:  You could ask a main dealer for a written quote for a new clutch, they should list the part number on the quote. Other than that, maybe Lighty will be able to find out.
Thanks for reply
I think most of the 90hp versions had a standard flywheel but don't quote me on that.
Put your VIN into catcar then look up the clutch, if the friction plate has no springs it will have a DMF.
https://www.catcar.info/citroen/?lang=en&l=
My 2010 110PS XTR had a Dual Mass Flywheel, as previous answer I think the lower power versions are solid flywheel.
Matt
   previous
   2016 1.6 HDi 100 XTR Grey Met
   2010 1.6 HDi 105 XTR Gold Met
Hi and thanks for all your reply's. Just checked on catcar.info with my vin number and the friction plate is showing as having springs so it must have a solid flywheel. I've had a price from a firm called Calder Clutch's in Brighouse west Yorkshire  £ 45  for a 3 piece kit. and they have excellent  100% feedback on fleabay  Tel : 01484 721045
My garage tells me the 90hp is standard flywheel. My clutch judders too, I can drive around it but it's a pain in the...
Was - Berlingo 2ltr HDI 2004 to 2016
Now - Berlingo 1.6 XTR
engine light
Today 09:25 AM
M59 1.4 Petrol question
19-03-2025 06:12 PM
Cold Starting
Last Post: jboy012000
18-03-2025 10:46 AM
17-03-2025 08:12 AM
2015 Berlingo van for sale
Last Post: eddyale
16-03-2025 06:47 PM
Last Post: deejay_xb
16-03-2025 02:53 PM
» Replies: 29
2.0 HDI. engine won't start
16-03-2025 01:48 PM
Unusual Braking Problem
16-03-2025 07:52 AM
valeo alternator CL15 rebuild
16-03-2025 07:49 AM
15-03-2025 06:19 PM
