Lights
Hi just a general question I snapped the headlight switch today and can’t turn lights off but when I turn the engine off the lights also turn off. This is won’t drain the battery will it
Nope. I leave mine on and let the BSI shut them off with the ignition all the time.
That’s great thank you least I don’t have to worry about that now I have a 2017 Citroen Berlingo van
Thanks for the reply
No worries mate, enjoy the van, I love mine.
Could possibly be an MOT problem. Can you switch between dipped beam & main beam with a broken stalk? Also I believe the regs regarding headlamp use are different to DLR's
(16-05-2020, 01:02 PM)Pedronicus Wrote:   Also I believe the regs regarding headlamp use are different to DLR's
No, they're not. If you want your lights on you can have them on all the time. Only fogs can't be used unless the conditions require them.
I was thinking more of the switching arrangement.
Rear seat belt breakage
Last Post: Mad one
Today 06:09 PM
Today 05:49 AM
Yesterday 11:36 PM
07-09-2026 09:06 AM
Last Post: BDRichardson
06-09-2026 04:07 PM
Last Post: kulat
03-09-2026 09:59 PM
31-08-2026 08:50 PM
29-08-2026 08:39 PM
29-08-2026 08:26 PM
29-08-2026 05:45 PM
