Mounting a reverse camera
Hi,
Would anyone have any idea where to mount a reverse camera. In the Berlingo the back windows are white and the number plate is stuck to the chassis. Where would you even run the wire? The only option I can see is to cut a small square hole in the bumber but would want to avoid that if possible.
Thanks.
you need something like this....fits berlingo
                                                   https://www.aliexpress.com/wholesale?cat...pee+camera
https://www.aliexpress.com/wholesale?cat...ear+camera
    take rear plastic cover off rear door.also nearside lamp assembly, and then run camera wire thru nearside wire loom......then plice camera wire into reverse light wire
                 or try ebay
There is this,
https://www.ebay.co.uk/itm/182236817708
Or this
https://www.ebay.co.uk/itm/324051047356
Haven't decided myself yet which one to go for. Either one has a ready made route into the vehicle.
(20-05-2020, 11:40 AM)Zion Wrote:  There is this,
Or this
hi.....like the look of second option.....neat......never seen that one before......pitty i took the first choice....be careful there two types for rear lens..A/B.........Mines B
It took me a LOT of hunting to find that one, believe me. Do you know the years to which each letter refers? Or is it Car=A and Van=B
Thanks for the feedback. I have installed the front dashcam so I will go with one of these options. Never thought I could replace the light.
this fits mine  https://www.ebay.co.uk/itm/PEUGEOT-CITRO...SwuvpcSa3V
this the  [B] peugeot/berlingo Fitment...take urs out to check..........small screwdriver to left side of holder sorta push in sideways..unclip out.....if its the same as mine.........a bit fragile so don't over do it.......cheers...........plenty on you tude to show u
Ahhhhh sorry I thought you meant 3rd brake light one could be A or B. My number plate lamps are nothing like the one you linked, they are clipped at one end and then screwed in from inside. Mine are the all black ones with tiny white panels at the bottom for the light to get through.
(21-05-2020, 07:35 AM)Zion Wrote:  Ahhhhh sorry I thought you meant 3rd brake light one could be A or B. My number plate lamps are nothing like the one you linked, they are clipped at one end  and then screwed in from inside. Mine are the all black ones with tiny white panels at the bottom for the light to get through.
What I ended up doing as I already got the reverse camera with the front camera I took out the rear light assembly which was only 2 screws. I was then able to put this into the van facing me and was able to put the car in reverse so I could see which bulb was the reverse light. I then got a resistance meter and was able to derermine the positive wire on the connector going into the assembly. I took the red reverse wire that came with the camera and wedged it into the connector. All tested and working.
With a bit of double sided tape I mounted the camera under the number plate light. [Image: 8ML5XXX]
https://ibb.co/8ML5XXX
Last Post: andy@andymcm.com
Yesterday 01:47 PM
» Replies: 24
ASDA AdBlue 10 January 2026
Yesterday 09:06 AM
Sticky throttle
Last Post: knucklerash
11-01-2026 05:53 PM
10-01-2026 07:54 PM
Last Post: jippo
10-01-2026 05:39 PM
Fuel cooler and hoses
08-01-2026 08:00 PM
Last Post: uk_friendly_fire
07-01-2026 06:51 PM
» Replies: 37
06-01-2026 10:38 AM
05-01-2026 06:05 PM
Blower fan
04-01-2026 09:58 AM
