Threads: 5
Thanks Received: 3 in 2 posts
Thanks Given: 1
Hi does anyone know if the ECU’s are plug and play, or are they paired to the BSI unit? I’ve been told by a good source the key is paired to the BSI unit and not to the ECU.
Can anybody on this forum confirm this please.
Threads: 123
Thanks Given: 250
34
The BSI & ECU are paired AFAIK, but you can get unlocked ECUs
Threads: 5
Thanks Given: 1
The guy who told me the ECU and BSI aren’t paired was a car lock specialist.
Threads: 75
Thanks Received: 1,308 in 1,140 posts
Thanks Given: 223
164
The ECU is coded to the immobiliser, but as Cancunia said, you can buy unlocked ones (immobiliser deleted) from
https://www.hdi-tuning.co.uk/ for under £200 with no remap.
Extra for a remapped and unlocked one. Check their ECU page. They also sell on eBay but are cheaper direct.
Threads: 5
Thanks Given: 1
So Brajomobil, thank you for your detailed answer, so by your reckoning what I was told is correct. The key is coded to the BSI unit and the ecu and BSI are not paired.
If my ecu has an internal fault and needs replacing, can I just buy a 2nd hand one off eBay plug and play style?
Regards Chris
Threads: 13
Thanks Received: 139 in 113 posts
Thanks Given: 162
18
If you buy ECU without "key check" than it is "plug and play".
Be sure to double check that with seller.
Best regards,
brajomobil
Threads: 75
Thanks Given: 223
164
Exactly what we said to you earlier Chris, the ECU has to be unlocked and the immobiliser check deleted before it will work. Otherwise it will not authorise engine start.
Threads: 5
Thanks Given: 1
This is confusing .com
Brajomibil quotes “In M59 motorola chip ecu firmware there is a line in program that asks BSI if key code is ok.
If BSI send OK , ECU opens injectors and you can start car.”
So this statement says to me that yes the ecu and bsi are paired as in they talk to each other, but if I installed a different ecu would it ask the bsi the same question about the key code and work?
