Alternator terminals
I'm trying to fit a split charge system on my 2002 berlingo 2.0 HDI. I need to connect a wire to the L terminal on the alternator. Can anyone tell me which terminal that is?
Thank you
why don't take a feed of the + side of battery.......thru split charge.......then add a leisure battery.....then you won't flatten ur existing battery
(23-05-2020, 02:11 PM)gazahull Wrote:  why don't take a feed of the + side of battery.......thru split charge.......then add a leisure battery.....then you won't flatten ur existing battery
Cheers gazahull
The system came with a diagram, I'm just following what is on there. I've put everything else on, leisure battery is under the seat
Not 100% sure what you mean
i just thought it would be easier....one wire via 20amp fuse of + battery....fed thru bulk head
https://www.youtube.com/watch?v=I3p-Krysg1c
(23-05-2020, 04:59 PM)gazahull Wrote:  i just thought it would be easier....one wire via 20amp fuse of + battery....fed thru bulk head
That's a great video thanks. Shows how it works perfectly. I havent got the same as his, I have the other type that he was talking about where the split charger has to be connected to either the alternator or ignition swich ( I bought the kit a few years ago now )
Sorted it now thanks to that vid, found out which terminal on the alternator to connect to. Works perfectly
Berlingo undertray
Today 06:24 PM
» Replies: 15
Today 08:32 AM
Today 08:16 AM
03-03-2026 06:17 PM
03-03-2026 05:08 PM
03-03-2026 07:57 AM
02-03-2026 02:51 PM
02-03-2026 02:14 PM
Amdro boot jump for sale
Last Post: YTC1
28-02-2026 09:48 PM
Last Post: Muppets on Mars
27-02-2026 01:57 PM
