Threads: 20
Thanks Received: 17 in 14 posts
Thanks Given: 31
Hello" all,
Today i cleaned my fuel filler area, for the first time, it was filthy with gunky diesel.
I saw some thing that i hope you can help with.
This was a silver button under the fuel filler neck. It is sprung loaded and pushes in and out..what is it? A fuel line primer?
It's a 2001 1.9d with 322,500 k on the clock.
Threads: 23
Thanks Given: 46
5
It may connect to to sliding side door to stop it opening while your refueling the car
The following 1 user says Thank You to Trevor for this post:1 user says Thank You to Trevor for this post
• Carl.1
Thanks Given: 188
23
As Trevor says if you have a sliding door and the fuel cap is off you should not be able to open that sliding door although on the later ones ive owned it was a black plastic button not your silver metal button. Dont go trying to force the sliding door to try out the theory as if it breaks you are in a whole world of bother to fix it.
Are we there yet?????
• Carl.1
Threads: 20
Thanks Given: 31
Cheers chaps, i shall have another nose at it tomorrow.
Threads: 20
Thanks Given: 31
Tomcat and Trevor. That is exactly what it was.
It was stuck in its hole! When i liberally lubricated it it then popped out about half inch and now does its job of locking the door open when the filler cap is off.
Thank you.
The following 1 user says Thank You to Carl.1 for this post:1 user says Thank You to Carl.1 for this post
• Tomcat3
Threads: 23
Thanks Given: 46
5
Good news that you have fixed it.
• Carl.1
Thanks Given: 188
23
Thanks for reporting back that you fixed it im sure others will find it helpful.
• Carl.1
