Threads: 48
Thanks Given: 4
20
Those are eTorx.
You can find a socket set at most of the usual suspects.
It's commonly used on headbolts, so you might get to use them for something else later...
Thanks Given: 188
23
Give the bolt heads a sharp whack with a drift and big hammer to shock it then put the torx socket on and tap that on so it is seated good and solid.
Are we there yet?????
Threads: 75
Thanks Given: 223
164
Mercedes have used these bolts all over the car for quite a few years now. I think they give rapid purchase for a hanging torque tool in production mode with no chance of rounding off while trying to go quickly. And as you say, keeps the lightly-skilled tinkerers out of things.
Threads: 29
Thanks Given: 67
20
They are handy because when you have rounded them you can easily weld a big nut on top to get them undone with a hex spanner.
